Old 06-13-2019, 09:22 AM   #1
Gilles
Looks like a decade of accumulated grime. Get some engine degreaser, apply liberally, and wash carefully (low pressure). You might check around the AOS to see if it's particularly oily there, indicating it is in need of replacement.
+1
After the engine degreaser, I would use Simply Green to remove any oily residue and "low pressure" water as suggested by Husker
Regarding the oil leak, on my 987CS the power steering reservoir has two pieces (top and bottom) the leak could be from there, or from the cross plenum main intake tube (resonator..?)
Once you clean everything, you should be able to see it
PS: How does the AC hoses look like?
