Old 06-07-2019, 08:33 PM   #11
BYprodriver
BYprodriver's Avatar
You'll want the pressure plate and flywheel, and the bolts that attach. They'll balance it as an assembly, and then index it for you. Be sure to install it properly indexed.
And, when they tell you "I can't balance a dual-mass flywheel", you can come back to this thread and explain that to the nay-sayers.
The 2 piece flywheel must be pinned together to prevent movement while spinning on the balancer.
