Old 06-04-2019, 09:07 AM   #1
PaulE
I highly recommend getting this harness if you're contemplating adding the OBC. Thanks to this forum I found out that the 4th stalk could be added to an existing 3 stalk setup so that I didn't need to remove my steering wheel. When Pdwight started offering his harness that sealed the deal for me! This was one of my projects that didn't require any do-overs, I did the stalk and harness install, my independent Porsche specialist activated the OBC and it has worked right away and is still going strong a few years later. Be sure to use your reading glasses and count carefully for the wire insertions. Thanks again Dwight!
