Old 06-04-2019, 09:14 AM   #11
Gilles
Originally Posted by wrs986 View Post
So when I get the car on a jack and check to see if there is any play in the wheel and/ or if there is any noise when spinning the wheel and I find I don’t have any play or noise I could still have a bad bearing? How do you know if you have a bad bearing if there are no signs?
You have to listen carefully as bearing noises can be hard to ID, usually they rumble under load, like if you turning hard to the right, you should hear a sound change on the left wheel..
Hopefully what I am trying to explain makes any sense..
