Thread: Track alignment
Old 06-01-2019, 09:06 PM   #11
Topless
Track rat
Topless's Avatar
Most likely toe. When under heavy braking the car squats and the weight transfers to the front tires causing toe out. If you are running square NT-01s you can really put the car on it's nose and go significantly toe-out.
Two choices:
1. Re-align and increase your toe-in F/R to eliminate the wiggle under heavy braking.
2. Adapt your driving style a bit. As you enter a heavy braking zone, squeeze the brakes a bit earlier > allow for weight transfer > go full braking >then ease out of the brakes keeping the car totally settled as you turn-in.
Both methods work, #2 tends to be quicker over time.
