Old 05-27-2019, 10:24 AM   #2
jgopinath
Jakeg104
There's nothing wrong with those tabs. Just unscrew them from the trim pads and push them into the holes on the roll bar. Then you can push on the pads.
Brilliant! you're right and it worked, thanks!!
Originally Posted by KRAM36 View Post
Are you looking for these? Part # 98658075100
Appreciate you sharing the part numbers! If they do break when i pull them off the for the next DE event (a few are starting to look a bit ratty), this will be perfect!
Thanks!
2000 Boxster S- Silver/Boxster Red
'11 458 Coupe
91 Brilliantrot e30 M3- Restored to Factory
'17 RR SC
jgopinath is offline   Reply With Quote
