Old 05-24-2019, 12:22 PM   #2
Laminar Flow
Guest
Posts: n/a
Originally Posted by amagalla View Post
Keep in mind that if the fob doesn't work (won't unlock the trunks or unlock the doors), then it will have to be reprogramed to the car. That cannot be done without the original program code that comes with the fob (on a little paper tag attached to the fob:
Is the program code associated with the RFID module ("pill") contained in the key or the wireless signal used to lock/unlock the door? Or both? If it's just the RFID module then i should be able to pair a wireless donor PCB to the car (although it's not entirely clear to me how that could be done yet). If it's both, then the donor PCB idea probably won't work.
Also, could the lines of printed info right below the Porsche crest on the back of a donor key be of use in determining the program code? It sounds like I may be out of luck with the donor key idea unless i'm lucky enough to find one accompanied by its program code.
