Old 05-24-2019, 12:53 AM   #3
sfkjeld
sfkjeld's Avatar
Originally Posted by ndfrigi View Post
any update of your issue?
if still trying to find the sound, try to remove the engine cover access behind the seats and then find a plastic tube to use like a stethoscope while engine running. Try to listen to your water pump, various pulleys, AC compressor and alternator.
I eliminated several sounds from water pump, 2 pulleys and engine mount and now last one need to fix is my compressor but no time yet to do it. Currently I have around 107k on ODO.
You got it. Water pump. And thank you for the excellent pics. I decided I didn’t want to mess with bleeding the coolant system tho. My first estimate was $1000 to replace the pump. A bit shocking.
sfkjeld is online now   Reply With Quote
