Old 05-22-2019, 11:35 AM   #4
PaulE
I don't think you'll be able to do this unless you can disassemble the headlamp unit and reverse the low beam shutters in the projectors. The shutter is shaped to make the low beam pattern project farther onto the passenger side of the car to light up the shoulder and side of the road. That is if the light unit is that kind of projector and the shutter can actually be reversed. If it's not that kind of projector and the low beam pattern relies on a lens, you would need to be able to disassemble the headlamp unit, and replace the RHD lens with a LHD lens. You're not going to be able to make them right by adjusting the headlight aiming in my opinion. If that were the case then manufacturers would just make one headlight for both RHD and LHD and aim them accordingly.
