Thread
While I'm in there...
05-21-2019, 12:35 PM
2
Starter986
1998 Boxster Silver/Red
Originally Posted by
KRAM36
I don't think the plastic is strong enough to hold the weight of the rubber hose, especially where it bolts to the engine. These little ears that hold the pipe on break easily. This is what I'm warning about, breaking the ears.
I also don't think the plastic tube is thick/strong enough to use a worm-drive clamp and that's why Porsche just uses a tension type hose clamp.
Full picture link (large) from the tutorial shows how close the pipe is to the stater. Be gentle with it.
https://cdn4.pelicanparts.com/techarticles/Boxster_Tech/83-ELEC-Starter_Replacement/images_large/Pic5.jpg
Also reading through Pelican's tutorial on changing the stater, they recommend to replace or reseal your oil cooler.
https://www.pelicanparts.com/techarticles/Boxster_Tech/83-ELEC-Starter_Replacement/83-ELEC-Starter_Replacement.htm
Thanks, Pal. Yes... don't want to disturb those ears. I'll be gentle. And patient.
Installed an S cooler and the rings a few months ago. Thanks for the head-up.
Funland. SoCal by any chance?
Cheers!
1998 Porsche Boxster
Starter986
Find More Posts by Starter986
