Old 05-17-2019, 12:54 PM   #1
piper6909
piper6909's Avatar
Originally Posted by sfkjeld View Post
The sound is a low level clatter. Audible when at idle and low rpm in first gear. I think it only becomes inaudible because it is drowned out by normal engine sounds. It occurs to me now that it could be a failing water pump bearing. Does this seem likely if there are no coolant leaks? My first theory was a chain tensioner..... do they make a noise if failing?
Heat shield?
Manual or Tip? If it's manual, when you're in 1st, obviously your clutch would be depressed. If that's the case, I'd also suspect the throwout bearing. Try pressing and releasing the clutch and see if the noise changes.
