Old 05-16-2019, 12:59 PM   #2
Ben006
Ben-Auto-Design
Ben006's Avatar
I applaud your efforts, Ben.
However, running a round aluminum ball against a flat plastic surface is going to leave you with the same issue: play will develop quickly as the ball wears a groove into the plastic sleeve.
You need something more like the stock insert for the ball joint in order to distribute the load.
I chose the delrin insert, it's easier to make !
Since the ball rides on only a small part, each insert can be used twice, and you'll get two with each kits.
That should be enough to last a few years
And even after that, I won't sell the inserts for a crazy price, I want my parts to continue working for a looong time
I made a small modification, and the production will start soon
palmhero, if you are in the US, check with Uniwerksdesign.com
Ben
ASE certified Automotive Master Technician.
Porsche Tech in France.
www.benautodesign.fr
Ben-Auto-Design : Performance parts for 9X6 / 9X7
1982 928 S Euro
Ben006 is offline   Reply With Quote
