Old 05-12-2019, 02:08 PM   #19
mgfranz
The zip ties don't look awful, really. Almost not noticeable. That's the easiest part.
However, making your own can be costly, and very time consuming. By hand you must measure out each hole, mark them, and then comes the drilling. You can't use just any old drill, no sir. You must use a Dremel tool, and with the expensive diamond-dust carbide-aluminum tip. Then, meticulously you must drill out each hole and... here's where it can get really expensive: one drill-bit per hole. Further each hole diameter must be measured with a micrometer and, again, not just any off-the-shelf-micrometer... for it must be able to meaure hole diameter down to .000000000000000000000000000000001 of an inch for, if just one of those holes isn't perfectly drilled, well, you can imagine the shame and ridicule by fellow Porsche owners. Finally, the rubber edging must be sourced from Indonesia, as it is made from a special "Rubbercone", a hybrid material from the rubber tree and hard-to-find silicone tree.
That is why many people just break down and spend the money for the set.
1. Ordering a set from the Internet will take ~10 minutes, and ~$325 brand new.
2. Making your own will take ~375 man hours and $3K-$4K in tools. It's all those ****************ing holes.
I bet 78350 will just buy a pair next time.
Post a pic of the pair that you purchase. Likely 300-400 members closely watching this thread.
I can't agree. The material for the screen is available at any big store or even online, and a rubber gasket can be had at McMaster just by looking for it. In fact, I think I will make a set just for S&G, I bet I don't spend more than $20.
The metal can be cut with either a bandsaw, a handheld grinder with a metal cutoff wheel or a pair of hand shears. The rubber can't be more than $8 for a .063 U-channel, I'm sure this easy...Sounds like a fun project for next weekend, might even powder coat mine to match rims.
mgfranz is offline   Reply With Quote
