Old 09-30-2006, 07:30 PM   #12
ukchris
I bought an S... but because it was a great deal and a beautiful car. I'd say it comes down to which car you like best from a color, options and appearance point of view and how hard you really drive. Sure the S is faster but I'd bet there are a lot of people go faster in their base than I often do in my S. You only need the power if you're going to use it.
Other than that warranty is a big issue, if you want to get an extended warranty tey usually expect you to purchase it while still under factory cover, the 03 may still be in warranty.
Personally I love the glass window and would rather have factory than afternmarket, if you think adding glass after market makes things equal make sure you compare what you will get. I believe the after market glass is smaller and early ones had stitching issues.
How do the colors, interiors and options compare? If they were both base models and the same price which would you pick based on the options?
Toucgh choice, good luck! Bottom line, you'll be thrilled with either I think!
ukchris is offline   Reply With Quote
