Old 09-30-2006, 03:25 PM   #6
MNBoxster
Originally Posted by bmussatti
I don't know for sure.
But, running low on fuel is not good. You may have sucked some sediment into your fuel system or clogged your fuel filter. Also, I think our cars have the fuel pump in the tank, which helps to keep the pump cooled. When you run the fuel level very-very low, there is no fuel available to cool the pump, which can shorten the life of the pump.
Hi,
Sucking up any sediment isn't likely to cause the problem because the fuel filter will catch it. The Fuel Pump also has a screen on it, so that's not likely the issue (it's take practically a handful of sand to clog both of these to the point of fuel starvation).
More likely Bad Gas. It's wisest to buy your fuel from the busiest name-brand station in your neighborhood. Because they're busy, they are constantly emptying the tank and refilling it which allows much less sediment and moisture to accumulate.
Also, the no-name, discount, stations have been known for some unscrupulous practices. The last time Fuel prices peaked, I actually saw an attendant at a no-name station putting a garden hose down the tank spout. 50 gal. of water would allow him to steal $150 (@$3/gal.) from the station unoticed. In a 20k gal. underground tank, the dilution would be so slight that most cars' ECU would compensate for it and no one would notice. Hope this helps...
Happy Motoring!... Jim'99
