Old 03-31-2019, 04:31 PM   #11
Markt213
MarkT
Originally Posted by Markt213 View Post
Awesome thank you all for the info I will pull the filter tomorrow and dump some oil.
Question: Is it possible to use a top side oil remover to suck some oil out through the oil fill port like I do with a boat?
Thanks again!
e
So I just found out that you can’t use a topside boat oil remover as there is an obstruction about 8 inches down.
Now on to plan B pulling off the oil filter cover... when I changed the filter I filled the cover 1/2 way then screwed it on. If I dump this oil then put it back on empty will it refill on it’s own as this will put a big air bubble in the system.
Just wondering...probably a stupid question but better safe...
Markt213 is offline   Reply With Quote
