Old 03-31-2019, 02:42 PM   #1
SC-986
SC-986's Avatar
My ‘02 base is in the shop now for a bank 1 cam deviation issue. No plastic pieces in sump or filter and the deviation was bad enough to throw a code. Initial diagnosis is a “cam shaft tensioner adjuster” issue. They will replace the pads while replacing the adjuster.
2002 Boxster base - Seal Grey, 5spd trans.,ROW M030 upgrade, FVD Brombacher software tune
2004 550 Spyder Anniversary Edition, #1541,Tip, TechnoFix DOF IMSB upgrade
SC-986 is offline   Reply With Quote
