Old 03-26-2019, 11:59 AM   #4
AZ986S
AZ986S's Avatar
In my case, I purchased a used engine that had been factory rebuilt with the Large IMS bearing. I pulled the oil seal so it can be lubricated by the engine oil. I also track my car almost exclusively and it certainly sees enough sloshing oil IMO. So I have no plans on replacing it. So far, 60 hrs of track time on it and runs like a champ. I must admit that I also have a custom Accusump set up with a EBS oil baffle system, but that does not relate to the IMS bearing, but IMO helps in reducing M9x engine failure related to oil starvation. If you can design a low cost dry sump for these cars, you will sell quite a few.
2002 Boxster S - NHP 200 Cell Headers,test pipes,Borla CatBack,Competition Plenum,74 mm TB, EVOMS Tune,Tarett UDP,Eibach Swaybars,BIlstein PSS9s,TuneRS rear toe links,wheel studs,15 mm wheel spacers on all 4,EBC yellow stuff pads,Sebro rotors, EBS oil baffles,160 deg Thermostat,2 quart Accusump,full filtration remote oil filter,rad fan switch,custom gauge/switch plate, Race Capture data logging, 90K miles
AZ986S is offline   Reply With Quote
