Old 03-26-2019, 09:14 AM   #5
Nobbie
I've just redone all the brake lines on my RHD Boxster and found the worst bit of corrosion about 6" from where the line meets the flexi hose in the front right wheel arch. The line drops down and then up and behind the inner wing and then bends to take it across the car. It's difficult to see unless you look carefully. When I saw the corrosion, I rubbed it and brake fluid seeped out. The line broke very easily as I removed it. Have a look there as that may drop onto the caliper bolts if braking in a turn. Has your brake fluid level dropped?
Nobbie is offline   Reply With Quote
