Old 03-23-2019, 06:54 PM   #1
TNT79Bronco
More of a truck guy
Originally Posted by Quadcammer View Post
Hard to tell from pic, but usually vac lines like that require you to push the fitting together, pull a lip towards one end of the fitting, then pull the ends apart. Cant tell if this is the same type, but if so, it should come apart easily so dont go all he-man
Yeah. I have made tools to do that in a couple of fittings. I have some where you have to remove a clip, and hold a “lip” forward, as you pull.
This one has nothing like that. I have tried pulling pretty hard, pushing in hard, and forcing apart, by inserting something between the two shoulders. Nothing.
2002 Boxster S 6 Speed
TNT79Bronco is offline   Reply With Quote
