Old 03-12-2019, 06:12 PM   #10
SC-986
SC-986's Avatar
Yeah, I came across this video. Still, I don`t think it justifies the need for DOF. The IMS is submerged almost all the way to the top of the shaft when your level is at the max sign, and is submerged around half way up when it`s at the min level. So, the inner ring (that is fixed) is always submerged in oil that will carry excessive amount of oil onto the balls and the outer ring. Centrifugal force has nothing to do with this because the inner ring is not spinning. Ball bearings do not require DOF.
If this premise is correct then why did the Porsche engineers specify a sealed grease filled bearing and not a bearing with the outer seal removed?
2002 Boxster base - Seal Grey, 5spd trans.,ROW M030 upgrade, FVD Brombacher software tune
2004 550 Spyder Anniversary Edition, #1541,Tip, TechnoFix DOF IMSB upgrade
SC-986 is offline   Reply With Quote
