Old 03-02-2019, 10:22 PM   #1
Geof3
Originally Posted by Oldcarguy View Post
Hi Jim,
The filter info is listed on LN’s site (NAPA 1042 or Wix 51042). Worth a read. Be sure you understand the pros and cons of eliminating the oil filter bypass valve (info available via search). You use a filter cutter to open the filter for inspection. You have to be careful with the sharp edges! Very easy to use a Filtermag or two with the spin on.
That filter cutter is quite the contraption. I just use a pair of tin snips. Takes about 30 seconds. But, as mentioned, seriously sharp edges!
