Old 02-23-2019, 11:18 AM   #5
Sergio
Originally Posted by Turbodad View Post
I had a similar problem. Turned out to be the positive "ground" had corrosion. It is located in the engine compartment inside a small plastic rectangular box at the top of the engine near the fire wall. Pop open the box and check the connection for rust on a loose nut.
Thank you Turbodad. Battery was tested and fully charged up. Posts were clean.
Sergio is offline   Reply With Quote
