Old 02-20-2019, 12:58 PM   #6
10/10ths
"50 Years of 550 Spyder"
10/10ths's Avatar
Open the glove compartment.....
.....you see that owner’s manual in there?
THERE is your maintenance info.
Change the oil and filter every 5,000 miles.
Check your tire pressure once a month and inflate to the psi listed in the door jam sticker.
Change your brake fluid every two years.
Change your coolant every five years.
Put silicone on all your rubber parts once a year.
Clean out your drain holes every year.
Don’t fold the top under 40 degrees.
Let the engine warm up until it drops to a slow idle and then gently start driving.
After a hard run, let her idle for a minute before shut off.
Squirt some dry Teflon into the key slots once a year.
Stop worrying and just drive. It’s just a car.
Good luck.
10/10ths is online now   Reply With Quote
