Old 02-19-2019, 06:58 PM   #10
Turbodad
I had a similar problem. Turned out to be the positive "ground" had corrosion. It is located in the engine compartment inside a small plastic rectangular box at the top of the engine near the fire wall. Pop open the box and check the connection for rust on a loose nut.
2001 Base with 2002 3.2 DIY swap 97 "short shift" tip "Joe Toth" aerodynamics, Z top, painted headlights.
2001 Boxster 5 speed
Turbodad is offline   Reply With Quote
