Old 02-10-2019, 02:01 PM   #11
Quadcammer
Airbox should come out easily at this stage.
The boxster fuel rail tabs are just in the wrong spot. You cut them off and buy $3 worth of clamps rubber line clamps at home depot. They get tweaked and shortened a bit. Then you put a long m6 bolt through with one clamp ear above the intake and one below. Then put a nut below. That looks the fuel rail in solid. It took a bit of thinking but the actual doing it was fast and easy
