Thread: 100 Octane
Old 02-09-2019, 06:30 AM   #21
Ciao
Ciao's Avatar
Which results in less oxygen, by volume, in the cylinder. ;-)
You're both right. But ultimately it's the cylinder pressure which, as it increases, requires a higher octane (resistance to detonation). Thus: lower air density=less cylinder-fill=lower cylinder pressures = lower octane requirement.
Great explanation Maytag. Does that mean even if the P car was tuned (chipped) for 93+ Octane, at higher altitude the increased Octane would not make a difference?
5280 Cruising @High Altitude
Seal Gray & K&N Filter
