Old 02-03-2019, 05:24 AM   #11
Spinnaker
Spinnaker's Avatar
Take off the gas cap and listen while someone turns the ignition to the ON position. Do not turn to the starter position. You should hear a whirring noise from the fuel pump in the gas tank.
No sound, check the fuel pump relay first. If it is good, then the fuel pump might be bad.
