Old 09-25-2006, 03:09 AM   #1
Euphoria
Euphoria's Avatar
Send a message via ICQ to Euphoria
Exclamation Litronic Problem
Originally Posted by RENNX
Help!
Has anyone ever had a problem with their retrofit xenon headlights not functioning correctly? All my lights worked fine but recently I noticed the main headlights were not coming on, not even a flicker. I was curious if behind the headlight switch their could be a bad connection where it turns? Or is their a relay that could be blown? I checked all the fuses aleady. Is there a main wire that could've come undone where the lights are installed that is strictly for the headlights? If I call Porsche are they going to say I am screwed?!
ANY information will be very much appreciated.
Hi RENNX,
I currently have the same problem. The dealership told me i need to get a new light switch. What did you do to solve the problem? did you need to change the switch?
Your feedback would be appreciated because i have my doubts about what the dealership are telling me.
Thank you,
Euphoria
Euphoria is offline   Reply With Quote
