Old 01-24-2019, 08:27 PM   #4
KevinH1990
KevinH1990's Avatar
Originally Posted by ExplorerLyon View Post
Can the relay under the seats be removed/swapped without removing the seat?
I can see it and put my hand on it if I raise the seat. Here's the part number: 996.618.521.00 and a picture showing the relay, the bracket that attaches to the seat frame and the electrical harness:
You will need to remove the wiring harness which may be fairly tight. Then, if I recall correctly, the relay is attached to the seat frame with a plastic rivet. It may be difficult to remove that rivet with the seat attached to the car. You may need to remove the fasteners that hold the seat in place and tilt the seat so that you have enough space to access the plastic rivet.
