Old 01-21-2019, 01:38 PM   #2
redciv1
redciv1's Avatar
You may need to bleed the clutch slave cylinder with fresh fluid. (Brake fluid)
Thanks BY as that is a good cheap replacement. I just pulled some of the records that came with the car and the clutch was replaced about 30k miles ago along with IMS from LN. Oddly enough the RMS was not replaced and it looks like it is leaking. Maybe 1 drop after I get car back into garage from a drive. Think I read somewhere that oil leak could cause slippage as well?
redciv1 is offline   Reply With Quote
