Thread: What now?
Old 01-19-2019, 03:18 PM   #1
bob4a3
What now?
1999 boxster 130k miles Po455 (gross leak) CEL
This is what I've done so far:
Replaced purge valve (engine under manifold)
Replaced Vacuum control valve (on side of EVAP tank)
Replaced carbon canister valve (on canister)
Replaced Fuel Cap (OEM)
Replaced vacuum valve (on filler neck)
Smoke checked the entire system. Took off underneath panels to check for leaks (none)
I'm at a loss. No signs of leaks anywhere. followed all lines as best I could. I have read everything I can find about this but I have done everything recommended.
I know there is a pressure differential sensor under the battery at the fuel tank. Could this be not working properly?
Any help would be appreciated. I'm ready to pull what little hair I have left out!
bob4a3 is offline   Reply With Quote
