Old 01-09-2019, 09:00 AM   #1
Cunningr
Cunningr's Avatar
Wiser heads may prevail... but I would recommend paying to have a PPPI performed (post pre-purchase inspection). That likely will identify all things needing repair or maintenance... and then you can post on here for those wiser heads to recommend if it's a keeper or killer.
Good luck.
This is best advice given so far! I suggest getting an inspection even if your a wrench turner that way you can have a priority order of the things you need to address and can set a budget and go from there. As mentioned boxa.net has mostly UK members maybe you can find a nearby boxster owner willing to help out some.
