Old 12-31-2018, 03:19 PM   #1
Doug427
Originally Posted by seningen View Post
If you can pull the switch and have a multi meter, you can see which combination of pins shorts when the switch closes and is open otherwise.
If that works, then the switch is good. You can then probe the pins, should have 12v on one of them. If there’s no 12v, I’d check your fuses.
Idk if the switch controls latch directly or if there is a relay in the path.
There's 6 or 8 wires at the switch, if I remember correctly. Does anyone know or have an accurate diagram of what color wire does what?
Doug427 is offline   Reply With Quote
