Old 12-31-2018, 07:49 AM   #1
rastta
rastta's Avatar
I have the Firebottle RC-500 system installed in my Boxster. Bottle is in the frunk. One nozzle in the frunk, one in the passenger compartment under the dash pointed toward the driver and one in the engine compartment. Mine is the manual pull system. It runs FE-36.
"FE-36™ is proving to be the standard in-kind replacement for Halon 1211 in portable fire extinguishers. FE-36™ has comparable performance and efficiency to Halon 1211, lower toxicity, as well as zero ozone depletion potential. In a portable fire extinguisher, FE-36™ is discharged as a stream of gas and liquid droplets that penetrate into the fire area, ceasing the combustion process through heat absorption and a chemical interaction. FE-36™ is also a replacement for Halon 1301 in local application systems, such as modular systems."
rastta is offline   Reply With Quote
