Old 12-27-2018, 01:12 PM   #5
shacky
Shacky
P0453 is the code for the pressure sensor being above the upper limit, usually because of a short on the B+ wire. The repair tree is to check the wiring running from the pressure sensor at the tank to the DME, repairing any faults.
Thanks. I saw elsewhere that the sensor itself rarely fails. If it’s a real code does it mean excessive pressure?
shacky is offline   Reply With Quote
