Old 12-23-2018, 05:48 AM   #19
Ciao
Ciao's Avatar
Originally Posted by marsheng View Post
Things change shape when you exceed the stress point of no return. Standing for months does not make the rubber bend past its point of no return. So if you say it developed a flat spot, what has happened? Has the rubber 'flowed' into this new shape ? If that is the case, then the flowing must have been caused by gravity of just the bending of rubber. If that was the case, I doubt that cars would get 1000 km per tire before being bent out of shape. Heaven help you of you hit a curb, it will put a permanent dent in the rubber ?
Can anyone produce some factual information on what may happen ?
https://consumertire.com/blog/view/flat-spots-let-s-clear-up-some-myths-about-that
Marsheng,
You should reply to the link in the posting as it clears up some myths about flat spots. T
5280 Cruising @High Altitude
Seal Gray & K&N Filter
