Old 12-22-2018, 06:52 PM   #27
marsheng
Originally Posted by Ciao View Post
Flat spots can be permanent it doesn't matter the cost, type, of car you drive whether its 1 year or 140 years.
Things change shape when you exceed the stress point of no return. Standing for months does not make the rubber bend past its point of no return. So if you say it developed a flat spot, what has happened? Has the rubber 'flowed' into this new shape ? If that is the case, then the flowing must have been caused by gravity of just the bending of rubber. If that was the case, I doubt that cars would get 1000 km per tire before being bent out of shape. Heaven help you of you hit a curb, it will put a permanent dent in the rubber ?
Can anyone produce some factual information on what may happen ?
marsheng is offline   Reply With Quote
