Old 12-15-2018, 02:23 PM   #5
thstone
I used the Wevo semi-solid engine mount with the Wevo semi-solid transmission mounts. No problems with knock sensors (maybe I was lucky) but there was a huge amount of vibration. Yes, it was THAT much more. Ultimately, I went back to the stock engine mount but kept the semi-solid trans mounts. YMMV.
You can give them both a try to see if this fixes your problem and if the vibe level is acceptable - all you have to lose is some time and money.
Wevo Semi-Solid Engine Mount
Wevo Semi-Solid Transmission Mount
