Old 12-10-2018, 11:42 AM   #15
speedyspaghetti
+ 1..
Not sure about the vibration but pretty sure about the overheated rotor..
PS: If it has been sticking long enough, that particular pad will be 'thinner' but once I removed the piston and clean it (polished)
with steel wool and replaced the seals = no more sticking caliper
Fingers crossed...hopefully this is the issue. I'm probably due for new rotors anyway, so I'll probably replace the front rotors + pads, even if the caliper is the issue here.
speedyspaghetti is offline   Reply With Quote
