Old 12-07-2018, 05:26 PM   #19
The Radium King
The Radium King's Avatar
Originally Posted by MaxD View Post
Once you have threaded that arm out 20mm for your -4 degrees of camber your presumption of adequate is just that.
I'll stick with something proven to stand up to the abuse we all dish out. A 20mm shim.
so you know how much thread remains engaged at a 20 mm extension? i'd suggest that you are the one making presumptions?
btw, max shim is 16mm and thats another $32 per side. ps, i've seen a car go into the wall when the shim popped out of his rear lower control arm. it was a lambo, though.
