Old 12-01-2018, 07:04 AM   #14
Gilles
Originally Posted by Boxstard View Post
I did POR15 inside the tank and over steel parts like suspension arms, etc. with success, so I trust that stuff. And it is nasty when it gets on hands...
But I do not think it sticks well to plastic surface... without rough porous surface it can peel right off.
Boxtard, you have a point on plastic..
Ok, Plan B..?
Perhaps be by using an Epoxy (again on the inside), as I have done it as well on the X1/9 coolant recovery tank.. Please note that the X1/9 tank is shaped much simpler than the 986 tank
As once the Epoxy is fully cured, is definitely Not going anywhere the challenge would be to have a mix that is "runny" (..?) enough to let you cover the inside of the tank.
