Thread
Engine Tapping and Borescope Results
11-29-2018, 11:52 AM
Htci
Hello Fellow Boxster Enthusiasts,
Earlier this year I posted this video because of a tapping noise at idle once warm:
https://www.youtube.com/watch?v=HtHlYpICstI
At one point I thought it had resolved by topping off with oil but it returned. I recently switched to Castrol Edge 5W-40 and the noise seems to be louder then before. I've spent many hours researching this issue and watching youtube videos with similar sounds. I even timed the tapping at 300 taps/min which I calculated to be 5HZ and finally decided this must be a sticky lifter, rod knock would be a lower frequency I think, and that I'd live with it until I felt like taking off the cam covers to replace them. I decided to borescope the easily accessible cylinders on both banks and have attached pictures for your analysis.
The car burns very little oil (less than a quart per oil change which I perform no more than 4K miles apart), does not smoke, there is no oil in coolant and vice versa. The car runs strong besides the annoying warm idle tick. I've been running this engine in this condition for over 4K miles. Spark plugs on all cylinders look identical and all good.
While performing the borescope I found cylinder 5 to have what appears to be 3 non-linear "cracks". Cylinder 6 has at least one of these and cylinder, and cylinder 2 showed similar "crack". Cylinder 3 looked perfect (no cracks). Please review these images, I know they are not HD, and let me know what you think and what your experience is with these findings.
2004 Boxster S 79K Miles
Htci
Find More Posts by Htci
