Old 11-27-2018, 06:44 AM   #1
Starter986
1998 Boxster Silver/Red
Originally Posted by Quadcammer View Post
I'd take the studs back out if you haven't. They are easy to put in once the mount is in place and make it a lot easier to get back in. With the coolant lines out though, you should have no issues.
Also, you can lower motor more than 3 inches if it helps you.
The studs aren't in (the Yoke studs)... and the coolant lines are off. I believe my big challenge, doing this solo, is lining up the mount holes to the motor holes using a jack. The car is up on jack stands, Esco lowest setting, so it'll be under... out... under... out... under... out... under... out... under... out... under... out... under... out... under... out...
I'm hoping that everything will just fall, figuratively speaking, right into place.
1998 Porsche Boxster
