Old 11-24-2018, 06:18 AM   #2
Starter986
1998 Boxster Silver/Red
Originally Posted by Quadcammer View Post
Your alignment will be fine.
Its not great to have the car off the ground for a month, but you'll likely do no damage.
The coolant drain is on the bottom of the engine, no need to lower the rear. The car has like 6 gallons of coolant, so not getting a few liters out is no big deal.
i would however drop the front when you are filling to help with bleeding.
Thank you. I've a new plug for the coolant drain.. and will be loosening some hoses... and I'll be tackling the motor mount while I'm down there... and coincident the water pump... low temp thermo.
I will be dropping the front end to ensourage out the air. Thank you.
1998 Porsche Boxster
