Old 11-19-2018, 07:53 AM   #2
Dr Feelgood
Yup
If you go aftermarket, you need to run wires to a new amp in the frunk
IIRC, there is a MOST to analog converter made, but it a lot of $$ and not worth it
Frankly, add the rear speakers, replace the dash speakers and just use the factory head unit. It actually sounds pretty good.
Do a search, plenty of threads on this subject
So what is the difference? I've searched but everything I've read is on the Bose system. Also some things have said that the non-Bose system is easier to work with but no real details other than that. Does anyone know what the actual differences between the systems are? I know that the Bose system had really low impedance speakers and that was another issue. Is my system the same?
Dr Feelgood is offline   Reply With Quote
