Originally Posted by CJ_Boxster
I think that sounds right...Have you got a warning light on your dash for worn brakes?
If not, you do not need brake wear sensors.
If you did the change yourself it would cost you under $100
Yeah, the light came on which is why I got the quote. No vibration nor any squeel from the pads but the "break wear" light come on and off. Also, felt front and back of break rotors and its smooth so not need to turn the rotors.
