Old 11-13-2018, 10:52 AM   #10
The Radium King
The Radium King's Avatar
well, the size of runners on the 996 plenum doesn't seem to be bigger than that on the 3.2, i think the difference is length - the 996 units are longer, so you will see more of a venturi effect and better cylinder fill at lower rpms. they may actually reduce max hp a bit as the increased length would be seen as a restriction at wot, but raise the overall torque curve up a bit. and more area under the curve is the goal, not necessarily the max number.
if you think about it from a porsche design point of view, the only reason the boxster runners are shorter is so they could fit the engine in the car.
