Old 11-07-2018, 07:20 PM   #10
Javi Cooper
Originally Posted by Deserion View Post
FWIW the alarm only chirps if something is ajar when it's being set. In regular use it should remain silent (at least on North America-region cars).
Oh man I was so happy when I read this, but when I tried it the alarm is not chirping when pressing the remote with a door open either. In fact, it doesn't do anything at all. With everything closed lights flash and doors lock but not chirp. Oh, and the dash light is not blinking either.
Have you tried using the emergency release cable for the fuel door? Just don't pull it too hard and remove the whole pin from the assembly like someone did... It may need lubricated.
Where is this cable?
I took my plastic thingie out too.
Replace the actuator for the gas door it's not that expensive.
Yup, next on my list. I'm wondering if that has something to do with everything else (alarm not chirping, trunk opening - read on)
Also forgot to mention that while the trunk still doesn't pop open with the remote, sometime after all this happened the trunk started popping open whenever I pressed the button to raise the top It actually came in handy when the trunk levels lock stopped working in the closed position, but now it's getting annoying...
This car is haunted!
Javi Cooper is offline   Reply With Quote
