Old 11-04-2018, 04:33 PM   #14
jaykay
jaykay's Avatar
OK
Wow this looks like an ample amount of room for anything. What was your procedure to get that thing way up there? What is the lift spec on you jack?
Those look like Rhino ramps up front. Is there enough lip at the front to keep it from rolling off? Were some serious chalks used
I suppose you used the rear jacking points to put ramps under the front tires one side at a time. Then using the rear lower Control arms get stands at minimum height under the two rear jacking points. Then using the central location moved the rear up one position at a time.
I suppose one could use the rear lower control arms as well to get all the way up.....
986 00S
